Space Shuttle problem
I am on that dreaded step where you have to test everything to make sure all is good in the hood. Originally, when I pressed the start switch the claw thing would move and that was it. I found that the switch at the top was not being triggered all the way so nothing would move BUT even with that figured out (not fixed) the arm does not extend and gets to a mid point where it stops then goes back in a bit and stops again. I’ve tried adding the C14 part but that doesn’t help as it doesn’t even get to the part where the switch needs to be pressed.
Any help appreciated
Welcome to the community. Sorry to hear that you are having problem with the space shuttle. I hope @CustomerService can help you with it.
I did not have that problem but I do recall seeing in an answer somewhere else that moving one small part a couple of mm’s made everything work properly. You may want to look thru Space Shuttle problems using the search bar. There are many
When I built my space shuttle, the switch controlling the arm was not being pressed fully too. I fixed this problem using some previous scrap wood from the set to add onto so the switch would be pressed fully. I hope you resolve your issue.
Welcome to community. Sorry I can’t help you because I don’t have this kit. But I think @CustomerService can help you
Hello there,
We’re sorry for the trouble with your product. Could you please send us a short video showing the issue? Our team will check it and, if needed, send you free replacement parts.
If it’s an assembly problem, we’ll guide you through the steps.
Thank you for your patience and understanding.
