[Pro Tips] Some tools and tips
I’m currently doing a Chinese kit that came with glue but I’ve found it needs a finer tip for what I’m doing.
Then I recalled that I had bought glue with a fine tip so I’ve put this into practice.
Here are some tips and tools I’ve gathered along the way.
  1. The precision tip for glues. I generally use B7000 because of the needle tip but decided to try the glue in my current kit. It’s a good strong glue but there is no precision. So, I added the finer tip (as I’ve already said).
  2. Quilling tool. I bought this pretty cheap because I didn’t want get glue all over my good tool. It’s great for rolling things like scrolls (you can always adjust how tight you roll), and paper plants.
  3. Small scissors. These are perfect for fiddly cutting, or trimming the burrs from paper pieces.
  4. Emery boards. I picked up these quite cheaply and like them for more precision when sanding burrs.
    They are also perfect for when you break nails while building!
  5. I thought of showing you my sharp awl as well for piercing things, clearing the nozzle of glue bottles, and stabbing things when nothing goes right but thought that showing such a violent tool may not be allowed!! :winking_face_with_tongue:
How funny i have most of these in my tool box except for the quilling tool. Very clever.
I love when you can use tools for more than one purpose :grin:
My emery board is used most often on both kit and nails lol.
Good starter tools ! Thanks for sharing!!
@Carmie an emery board doing double duty for kits and nails might be the most honest builder tool tip of the day. Useful, cheap, and somehow always needed.
These are all great tools to have. The quilling tool would be especially essential when dealing with flowers or plants. Thanks so much for sharing
You are so welcome. Sometimes the best tools are the unexpected ones.
I’m happy that I can use most of these tools for other uses lol
@Suzanne_Jones this is the kind of practical tool post builders quietly save for later. The precision glue tip, quilling tool, small scissors, and emery boards all solve very real tiny-build problems. The awl joke also feels painfully relatable on stubborn build days.
Would the long nozzle causes blockage when it dries up @Suzanne_Jones ?
That’s a very good question…because I received a long nozzled bottled with a crafting kit that I won on IG. I have never put glue into it because I was afraid that might happen. @Tricia12
These are very useful tools. I usually have some sandpaper left from kits I made. I also keep a toothpick close because I that also can help me out in some situations.
It hasn’t blocked up on me yet @Tricia12 and @Nita_Davis. The glue goes back down the tubing once the pressure is released on the glue tube.
That’s cool that you keep a toothpick as well. I should add some to my tool box.
Thanks for sharing what tools you use. This will definitely be helpful if I ever do some smaller kits. I’m mainly doing 3D puzzles right now though.
I actually bought a bottle to put my glue inside! Its a very fine tip
Many tools are in kit. Thank for share
You’re welcome @Zoe_Lau. Some things can work well with both the puzzles and the miniatures. We all find what works best for us.
I have them as well but in this case, the addition of the precision tip to the glue tube worked very well.
