I have to say my kit has not been easy. Lots of fragile boards. I struggled with the first cabinet which should have been basic. I then cracked the ladder, which I should not have. Many of my pieces, while snapping together, split. I think some of it was due to me painting in advance. I should not have done that as it did swell a bit. I ended up having to sand nearly every tab.
Advice if you choose to paint this build, wait until you have built, then paint! I circled the pieces that called out for super glue!
I got through it though and am nearing the end. A few more things to complete and then I will stage.
The only painting I did was on the side door, the pinkish-purple stripe, and the yellow peg board. I painted the door a more cream/beige color. The stripe on the wall looked too purplie so I painted that same as door. Hard to keep the lines straight even using painters tape! And I have never seen a yellow peg board in a mechanics garage so I pinted it a more traditional color!
I’m curious to see what crazy posters you will be putting in the garage kit. Thank you for the helpful tips. I’m going to take note of that about the painting tips to the wood. It’s looking really great.
