👍 [Rolife - Challenge & Achievement] Garage Update for Jeanne
Once I got it all together I could see that I could have waited. But you dont always know that and honestly I do not usually look ahead that much
Step by step and see how it goes. I’m sure whatever you choose in the end would be great. :+1: :blush:
I’ll start doing this next time I find gears or areas rubbing together thank you!!
You’re welcome.
I usually paint before I build but that’s a good tip if I ever get to this kit - to paint after I build. :pink_heart: It’s good to know that the pieces are fragile too.
I am starting the fairyland tree house and will paint after built. Going much better
@jeanneL Great Job, Jeanne!
I had the same problems too! I am glad you got it sorted! The power of glue saves my builds !!! ahahah
Oof, that sounds like a real challenge, @jeanneL! :sweat_smile:
But you pushed through it, learned from it, and it’s looking great!!!
Thanks @Nita_Davis I wanted it to look more natural.
I just kept plugging away! I was on a mission.
As Tricia said, smooths and gets rid of rough edges, but can also help a tab to slip into place, that way you are not forcing and breaking. In my case, I painted in advance which made the board swell a bit. That then makes the tab a little bigger and will crack or split.
I think so too!
Thank you!
I was surprised. I was pushing lightly and then it just splintered apart
I admit it is nice to not be alone on that! But we got through!
