Hi! Does anyone have any tips or tricks to pull the Super Creator kits apart? I want to connect my kits together, but I’m having a hard time figuring out how to pull them apart.
I’m using the connector piece in the photo. Do you just brute force pull them apart? Or is their a sweet spot or tool to use?
Hi there! Welcome to the community @Taytos_world
They can be a bit tricky! Try wiggling the pieces gently instead of pulling straight out, it helps loosen the connector. A thin tool (like a small flat screwdriver or craft knife) can also make it easier without forcing too much.
Thank you for the tip! I haven’t connected the other kit yet, since when I popped in the cylinder connector it made a very secure click. So I was afraid it wouldn’t come out. Perhaps it better to connect the two kits and use a flathead screwdriver like you said to separate them. Thanks again! @Wenbare
Thanks for everyone’s support! A friend of mine @Smiskiville also gave me a helpful tip using the tweezer that comes with the kit. I’ll attach a photo and video. It worked like a charm to pop out the cylinder connectors!
