The rolife puzzle, sunshine town, has a step where wires are inserted in a tube. Then the tube is heated? to shrink and bend it. What’s the best way to do this. I never had to do this heating step. Please help.
Thanks.
I know that lots of people have used a lighter or a hairdryer
Some have used like a heat gun for crafting. honestly I take a lighter and hold it a few inches away. then run the tube (with wires inside) quickly back and forth. This causes it to shrink. Just do not hold too close or it will melt.
I had to look this one up because I haven’t done that heating step either.
For the Sunshine Town, it’s a heat-shrink tube, and the safest/easiestmethod I’d recommend is a hair dryer on high heat. Hold it a little away from the tube and move the air around it until the tube shrinks, then gently bend it into shape while it’s warm. Rolife also says a hair dryer can be used, although it takes longer. I’d avoid letting a lighter flame touch the tube because it can scorch it; if you do use a lighter, keep theflame very close but not touching the tube and move it constantly. Hope that helps, and don’t worry, I’d be nervous about this step too! ![]()
I’ll be honest, i skipped this part of heating and applied an electrical tape instead. I saw some use lighter but like a flame kiss approach only
Yes a lighter is quick and easy. Electrician use them all the time.for.heat shrink tubing.
You can use a hair dryer or a lighter, though I usually use a heat gun.
I probably would use a heat gun but I know many people also use a lighter. Either one should work.
Hope you find some helpful tips in the comments! ![]()
I used a candle so I could hold both ends and heat the tube evenly. You don’t even need to hold it close to the flame—just close enough for the heat to soften/melt it. Another option is to use a hair dryer on the hot setting.
I’ve never built this kit, but I see you’ve already been given some advice.
it was my first kit !
I used the lighter method. I have a light with a long nozzle. Waved the shrink tube above it and it shrunk to fit the wires. Then I bent the tube at a right angle and it looks good.
Thanks for all the advice. You all are very helpful.
