Slide not releasing on Space Shuttle
Text
[/center]*
Welcome to the community @David_Randolph maybe this article will help, read the reactions, Robotime had send a picture, hopefully this is your problem too.
Check at Page 22 and see if part C14 is well euipped
Hi @David_Randolph
Welcome to the Robotime Community :smiling_face_with_three_hearts:
Our customer service will help you soon
Hello,
Based on the normal operating mechanism of the product, when the landing gear is retracted, it should press down the T3 switch, and the landing gear will stop moving at that moment.
However, according to your description, the landing gear does not stop, which indicates that the T3 switch may not be properly pressed.
A common cause is:
:wrench: Part C14 may not be installed correctly or may not be fully in place, so when the landing gear retracts, it cannot press the T3 switch.
We kindly suggest you check the following:
  1. Confirm whether part C14 is correctly installed and secured.
  2. Try manually moving the landing gear to see if it can press the T3 switch properly.
If possible, please send us a photo or a short video, and we will assist you further with the troubleshooting.
Thank you for your patience and support. If you have any other questions, please feel free to contact us. :blush:
Welcome to the community @David_Randolph I hope you have found the answer to your problem from the amazing members of this group
