The little house is finally starting to take shape!
The walls aren’t completely finished yet, but it’s beginning to look like an actual little Moomin home rather than a collection of tiny pieces.
This round also came with a little excitement—the lighting fixtures are in!
I attached everything, connected the wires, and tested the lights… and thankfully, they all worked! Whew. ![]()
Now, keeping those wires neat and tidy… that’s another story.
I clearly need more practice in the wire-management department because mine are looking like a tiny, tangled jungle back there!
And apparently, wire management isn’t my only problem.
I also realized I placed the curtain slightly too far to the left. It really should have been moved to the right, because the beam ended up catching it. Unfortunately, I had already glued the curtain in place before installing the beam—so by the time I discovered my mistake, it was too late. ![]()
I’m choosing to call it a design decision and move on. ![]()
A few observations about the kit so far: the house frame uses snap-on pieces, which makes assembly quite straightforward. However, I think I’ll probably glue some of the parts in place rather than rely entirely on the double-sided tape suggested in the instructions. I prefer a little more security, especially for something I’ll eventually display.
The touch sensor for the lights is also attached using double-sided tape, but I think this will eventually come off. There aren’t any screws included for this part, so I’ll be raiding my toolbox tomorrow to see what I can find to keep it securely in place. ![]()
Overall, though, the lighting itself has been surprisingly easy to install and get working. My only real challenge so far is convincing all those wires to behave! ![]()
The walls aren’t quite done, the wires are a bit of a mess, but we’re definitely getting somewhere!
