“I can’t find the points I earn through the daily wheel of fortune. I don’t understand where I can see the total number of points.”
When you go to your profile, select the expand option, you can see the total number of ‘cheers’ which are the points on the leader board.
You seem to have a total of 815 points at the moment.
“Oh, thank you so much! But what can I use them for, and where?”
You cannot use them for anything. The points that you gather count and give you a position on the leader board. At the end of the month the ranking on the leader board counts. And first 30 people win a prize.
You can read the rules and more here
“But is 815 a lot? Anyway, I was trying to find where you can see the total points you get from the daily Wheel of Fortune — are those the ones?”
You cannot see those points separately. You just see the separate messages you get after spinning the wheel.
Concerning the leaderboard and the points and if that is many or not. Just read the post I just mentioned and maybe also
How to Master the Community.
It will give you the answers you need.
“Ok, thank you so much, but when are the winners announced?”
Normally the first of the month, unless mentioned otherwise. But again… read the posts I mentioned and all will be clear.
Okay thanks you so muuuuch ![]()
The wheel points go towards your Leaderboard points exactly how Minis explained ![]()
You can see them on your profile as others have mentioned, or on the leaderboard.
The points are for the leaderboard. You should definitely read the article that the others shared. If you’re in the top 30 of the leaderboard at the end of the month, you’ll win a prize.
Thans so much to all ![]()
