👍 [Beginner Tips] To Paint or not to paint? Tips to share with everyone
Everyone has their own style own style, preferences, idiosyncrasies with their build processes. There is no one set way to do anything, find your niche and enjoy making these kits.
Tip 1 read the assembly manual front to back. Review completed builds by other constructors, read the manual again referencing one or more of those builds. THEN, decide on your theme for painting. Out of the box it’s a Circus themed build so if your theme is also circus, begin thinking which parts are which colours. Read the assembly manual again as you chose your colours. One of the most striking themes I’ve seen used a wire screen to help apply contrast and nuances based on that constructor’s chosen colours. That final build was stunning.
Tip 2 Paint or pens ? It all comes down to preferences of the constructor. Some only “paint” while parts are still on the boards. If using pens then that does tend to make sense, I guess. Demounting afterwards, from the boards will still requiring sanding and maybe touchups. Do you edge paint or not ? Again, personal preference. Edges are hard to paint. Edges don’t like to accept paint. I paint all my edges, then sometimes paint them again. I use only acrylic paints, then custom mix standard colours to arrive at my focus colour based on my palate theme.
Tip 3 Paint application. Pens are easy, until they are not. Some pens will do just fine until the tip decides to dump the ink. Always paint on a surface that will never be pristine clean ever again if using pens. I use 2-3 inch soft foam roller. Wash it out, should last a few weeks of painting. If you want a stipple type finish then always use a dryer roller. If you want a really flat finish add 2-3 drops of water to paint before using the roller. I use cling food wrap to cover my paint board. Use upside down painters tape to hold parts to the board for painting. If painting both sides, allow one side to dry at least 2 hours before trying to paint the other side. Why? You don’t want tape damaging your paint surface. Also, use clean food wrap, don’t be cheap and try to get several paint cycles from the food wrap. Soft paint (not fully cured) just loves to cling to food wrap. It leaves a different surface finish on the parts as you pull them off.
Tip 4 enjoy the build process at your own desired pace. It’s not a rat race to the finish line. Enjoy the build means just that. I only paint in natural daylight, never in the evening under artificial lighting.
Thanks for the tips @Joe-K
I havent painted very much yet but I am hoping to do some customising and more painting in the near future! Super helpful!
Thanks for the tips. I’m thinking of painting the space shuttle
I paint everything with acrylic paint and a brush. I’ve discovered that this allows me to paint more precisely. Sometimes I wipe while the piece is still on the board, and sometimes I remove it first; it just depends on how much space I have on the board. If you don’t apply the paint too thickly, you can apply another coat after a few minutes if necessary. Sometimes I use acrylic markers to paint the edges, but then several coats are needed to achieve full coverage.
Would be nice! Curious to the result :grin:
Really great advice @Joe-K! I love how you highlight that everyone has their own style and pace. It’s so true that these kits turn out more special when you make them your own. Thanks for sharing all the painting and building tips, super helpful! :smiling_face:
I can’t wait to see the result. It’s a kit that I find really impressive :star_struck:
Hi @Joe-K , thank you for taking the time to writing these valuable tips. It is very helpful for our fans, especially for the beginners. :sparkling_heart:
Wow, thank you so much for sharing these detailed tips! :raising_hands:
I really appreciate how you emphasized finding your own style and enjoying the process — that’s such a good reminder that these builds are meant to be relaxing and personal.
It’s a very novel idea. Your suggestion helped me. I used to only use acrylic paint and brushes to paint a lot. Now I have a new idea.
Wow, thanks for sharing.
Welcome aboard!
Another masterclass expert!
Looking forward to more content! :clap:
Wow, your tips are super valuable — thank you for sharing them here! :raising_hands:
I’m actually preparing to add some colors to my ROKR kit, and your advice really gave me some inspiration and confidence to try. :artist_palette:
It would also be amazing if you could share some thoughts on other parts of the process, like waxing, wiring, or even how you organize your toolbox. Those would be super helpful too! Looking forward to learning more from your posts. :folded_hands: :heart_eyes:
Your tips are incredibly valuable—especially for a beginner like me looking for painting ideas. Super helpful! I’d also love to see more on wood waxing, LED wire routing, and what’s in your toolkit.
Hey there! Just read your post and wanted to say thanks—your timing couldn’t be better! I’ve been wanting to paint my own ROKR model but was kinda nervous about where to start. Your tips really gave me the confidence to just go for it. :grinning_face_with_smiling_eyes:
If you don’t mind, I’d love to hear more from you—especially about things like waxing techniques or how you handle wiring in your builds. Those little details really make a difference, and your advice clearly comes from real experience :two_hearts:
This is such a helpful post—thank you for sharing your tips! :artist_palette:
Thank you so much for sharing these incredibly detailed and practical tips! :raising_hands: As someone who’s fairly new to building and painting kits, this is exactly the kind of guidance I’ve been looking for.
Thanks again. It is really helpful.
Absolute masterclass! :raising_hands: This resonates so much. You’ve perfectly put into words the entire thoughtful process that makes this hobby so rewarding.
Wow, thank you so much for taking the time to share these incredibly detailed and practical tips! :raising_hands:
Your advice couldn’t have come at a better time. I’ve been a little nervous about painting, especially how to handle edges and which tools to use, but your tips about acrylic paints, soft foam rollers, and even the cling wrap trick are total game-changers for me!
Also, if you’re open to sharing more of your wisdom someday, I’d absolutely love to learn how you handle things like wax finishing, wire routing in mechanical kits, or even what kind of toolbox or organizers you recommend for keeping tiny pieces safe. Your insights are pure gold!
Thanks again for lighting the way—you’ve already made my next build feel less intimidating and way more fun!
Can’t wait to see more of your posts :clap:
Thank you for the tips @Joe-K
Very good read especially for beginners like me.
Your tips are so detailed and thoughtful — thank you for sharing them!
