as I said in another post, I use these metal tweezers to remove pieces. I found a few in this kit that did better with this. There was one piece, a white little frame for a red window, that cracked a little. I did not use this and I should have!
The pics are not completely in order so will address based on shown here. This part was the lantern. I originally put together based on directions but found the “glas/paper” piece was hard to p,ace proerly. If I removed 1 side of the lantern, p,ace the glas, and then replaced the black frame, it lined up better. So I recommend that.
Such a lovely model. I like the fact that you are using tweezers but I will always stress that cutting the tabs that hold the pieces in are the best way to avoid breaking. As for the door not opening and closing as well as it should, sanding ( and sometimes waxing) of any edges is always helpful to make things move easier. This is going to be a very lovely kit when done. Thanks for your tips on the lantern.
Thanks for sharing these tips, they’re really helpful! The lantern advice is great, and that window detail looks so pretty. It’s always nice to see the little touches that make the build special. Looking forward to your next update!
I did try with my X-acto knife and it was almost too big. What are you using and if that - blade size? I prefer to be safe, especially with the guitar one soon!
Thanks Nita!
I just used a regular old razor blade. They come in a black protective case where you can reverse the blade to safely pack it away when you’re not using. That case becomes the handle for me @jeanneL
