👍 [Beginner Tips] Help for dream factory
At first my little conveyor only worked when I moved it manually. After assembling all the pieces it wouldn’t work. Upon looking closely, one of the Christmas tree decorations fell off and was blocking the gears that moved the conveyor. The other little issue I had was the gear would turn when I applied a little pressure holding it. When I let it loose, the conveyor would stop. I found out that I hadn’t screwed in the little screw tight enough. That solved the problem.
Is everything working now?
Thanks for sharing these tips. Little things like that can make all the difference with the factory. Glad you got everything running smoothly!
Thanks for the lovely tip! :heart: I think someone else had a similar problem with the decoration so definitely something I’ll keep in mind. :blush:
Welcome to the community. Great to hear you solved your problem.
Hiii @Peggy_Breitner ~ It’s great that you figured everything out! Sometimes it’s those tiny decorations or a single loose screw that make all the difference, and your careful troubleshooting really paid off. Thanks for sharing these tips, they’ll definitely help other builders too! Enjoy watching your little conveyor run smoothly now! :christmas_tree::sparkles:
Thanks for sharing the tips, does it work properly now?
Yes, thanks for asking. Everything works great!
Yes, Liset, thanks for asking.
Thanks Jerry
This is an excellent tip for troubleshooting. Hope all is well now
I’m glad things are working for you. This is such a beautiful kit.
