[Pro Tips] Rubber cement erasers
This is a great tips, thanks for sharing. Do you need to wet it before use?
Thanks for sharing! I don’t usually use that much glue but if I ever do, this will come in handy.
@Liset no you don’t, it’s just rubber. And as you use it, the residue that you are cleaning up just balls up and you remove the used pieces from the eraser.
@Zoe_Lau I glue every single piece of ever build, but if you don’t, I can agree that you wouldn’t need this.
I also actually cut one of those down to a small pencil shape and use that when I get too much glue on one of my models too. I let the beacons three and one dry a little bit and then I can rub it right off without a eraser these are definitely so useful!
I am going to need to look into those. My mat is getting yucky and the acetone and other stuff removed some print on it.
Side note, I also glue things down. Most everything. Once in a while I may leave a chair free
Ohh this is interesting! :thinking: I’ll definitely check these out! :star_struck: Thanks for the tip! :smiling_face_with_three_hearts:
Wow! The tool is like magic. :heart_eyes: I’ve never seen it before. I’ll bookmark your post for future reference.
@jeanneL I do the same, rarely leave things loose. Once in a while I think grandkids will want to have something to move so I leave a chair or something unglued like you do.
@khimmymade you’re quite welcome!
I will look for them on Temu, I always have super glue on my fingers. Thank you for the tip!
You’re quite welcome!
