👍 [Pro Tips] Electric tips & tricks
Somebody are afraid of electrical connections of model kits. If they have more lights, you have problem to connect. Because the link is so fragile, the light will flicker.
So I solved the problem by using:
You can also use straws or big heat shrink to hide the wires. That makes the model more beautiful.
Thanks for sharing your tip, the straw tip is great as I hate seeing wiring.:wink:
I saw this kit with the gun on alie express and thought of buying it. The idea with the straws is really good
A really useful information. Thank you for sharing it with us!
What a great idea! I always hate the look of the exposed wiring. Thanks for sharing.
I used the heat shrink that came with Cathys Flower house. I thought I heated enough but they are still flickering. This was an issue with my Chocolate shop one as well but did not have the heat shrink, just the tape. Unsure what I am doing wrong. I make sure they are twisted together well but the wires are so fragile coming from the LED
