Pro-Tip: Gang Test Lighting Test Rig
This is how I both gang test and single test lighting strands.
To make this rig:
Purchase short set of 3v battery operated fairy lights, cut off the lights, You will need about 4-5 inches(15-20cm) of cable attached to the battery box.
Remove insulation from the wire ends, twist separately
each wire end to form a solid wire.
Will need some time of connector block like shown, label one side red other side white-blue, what ever.
Connect to the battery box.
Your test rig is now ready for use.
I added a second connector end test feed for a testing one strand by carefully inserting the test strand wires into sockets. Your test rig does not need that second connector setup.
In the attached photo all four lantern lights are on via the test rig.
Hope this tip is useful and someone sees value in testing lights before they install them in their builds only to find out there is a broken connection at the actual tiny light.
Cheers to all the builders out there. Enjoy your builds
