I would like to thank @Robotime gave me the opportunity to test this incredible miniature kit!
This greenhouse garden consists of 1,168 pieces ( with level 6) and it is definitely a project that shouldn’t be underestimated. It is one of the most beautiful miniature kits I have ever built.
The greenhouse itself is absolutely stunning. The transparent walls allow you to admire every detail inside, while the window frames are beautifully designed with impressive depth and dimension. Robotime even includes decorative trim pieces that create a realistic layered effect, making the entire structure look like a real greenhouse instead of just a model.
One feature I really appreciated is that the kit comes with a paint pen, allowing you to touch up the exposed wood edges so everything matches perfectly. This small detail makes a huge difference in the final appearance and gives the model a much more polished, professional finish.
Inside the greenhouse, every corner is filled with beautiful plants and flowers. The level of detail is simply amazing. My favorite part is the small pond, which uses a reflective surface to imitate real water. It looks incredibly realistic once completed.
Another feature that really impressed me is the removable front and back doors. Once the greenhouse is completed, both doors can be easily detached, allowing you to admire the beautifully detailed interior from different angles. It’s a thoughtful design that makes the finished model much easier to appreciate and display. This is a unique feature that I don’t often see in other miniature kits, and it really adds to the overall experience.
One more pleasant surprise was the flowers and leaves. Instead of asking builders to cut every single petal by hand, many of the pieces are already pre-cut, making the building process much more enjoyable while still achieving an impressive 3D effect.
The warm LED lighting brings the entire greenhouse to life. When the lights are turned on, the garden feels cozy, elegant, and incredibly realistic.
Of course, beauty comes with a price.
This is not a quick weekend project. It requires a great deal of time, patience, and dedication. Some trees contain over a hundred individual leaves, and every leaf must be attached one by one. There are four greenhouse sections filled with countless potted plants, flowers, and greenery, with many petals and leaves needing to be assembled individually to create the realistic layered effect. Some trees are also built using wire wrapped with paper, adding even more realism but requiring extra patience during assembly.
This kit is definitely designed for experienced builders who enjoy detailed craftsmanship and don’t mind spending many hours creating something truly special.
If you love plants, greenhouses, or highly detailed miniature projects, I highly recommend this kit. The final result is absolutely breathtaking and well worth the effort.
However, if you are new to miniature building, I would suggest starting with a simpler Robotime or Rolife kit before taking on this masterpiece. It is a challenging build, but the sense of accomplishment when you finish is truly unforgettable
