[Beginner Tips] Ornaments Emily's Flower Shop
Hello, I am just about to start putting the plant etc on the small shelf. It says there are ornaments number three and four but I can’t find any details on these in the instructions. There’s also ornaments on other stands. Could somebody help me with these please, I don’t want to use the wrong components.
Perhaps it would help if you showed photographs of the paper guide so we can see exactly where you are.
You could show the photos or you can get @Robotime to help you
Robotime rarely runs out of supplies. If you do, please contact @CustomerService
Are the ornaments not in the bags supplied… or do you have to make them???
I don’t have missing parts
I don’t think they are missing, but there is nothing in the instructions to say what you use to make the ornaments
@Clare_Preston as said @ robotime could help you if you have any missing parts ! I hope this helps :cherry_blossom::cherry_blossom::smiley::smiley:
They aren’t missing, I just want want to clarify what parts are used to make these ornaments as there are no instructions.
If it is an older kit then you need to make it. Can you tell from the photos and relate from which parts you are actually seeing? I usually just go by photos.
It’s the older version. That’s the problem, the picture isn’t clear enough to identify what to make them with!
I got this kit but I haven’t build yet. I should be able to check it out tomorrow from the manual and let you know is that ok?
That small vase is usually made from square white bead and a small grommet. As I recall there was an instruction section on ornaments in the manual somewhere?
It’s this page in the manual.
@Clare_Preston oh i see ! I hope someone can help ! :blossom::blossom::smiling_face_with_three_hearts:
They’re always out of the question and you have to glue them on. I think you skipped a step in the instructions. I did it; the manual is quite clear.
I would contact Robotime. They can probably help you and they have excellent customer service.
Haven’t done this yet. Maybe its from the first pieces that you already have built. That’s some of the instructions are.
I would say that they are beads. If you have beads like this then they will be your base.
I think the ornaments are already on the plastic bags and you just need to place them on the shelf? But you can check on the paper guidelines. You can see the ornaments there I think and which plastics bags they’re placed.
