The ROWOOD Glittering Water Lily is my next build.
This is day 1 and how it is packed and what is inside the box after unboxing. Let’s have a great building journey together building the ROWOOD Glittering Water Lily
I have been thru the instructions and it makes me a little nervous
Thanks for sharing! I’ve built this one a couple of months ago as a gift for my mum’s birthday. It’s a fun and not that long build!
It’s pretty easy-ish all the way around. I do have two tips to give you though:
The first one would be to be really and I mean REALLY careful when you’re moving the “paper wire” of lights through the structure. It’s not like it’s gonna easily break, it’s more that you need to take real care to which side the lights should turn and through which holes you’re supposed to fit it.
The second one would be to be careful as well during the last steps; there’s one step in which you’ll fit one big plastic piece which is supposed to resemble the water, and then you’ll have to fit some long “stems” with the water lilies through the small holes in the plastic to the small holes in the “floor” piece below it. You wanna have a proper light so you’ll be able to see the holes in the “floor” and “hit” them with the stems without going crazy
So happy for you <3 Can’t wait to lay my fingers on this set I usually love when there is a lot of pieces and the more complicated the better but this one is just soooooo adorable. Have fun!
This one is going to be beautiful! If you can make the Lighthouse you can also make this one @Sofie_Vanderbeken i’m making the starry night from rowood at this moment, it is a different kit @Jerry_Boswijk
