Tips & Tricks: Organizing Your Wood Sheets with a Letter Holder
If you’ve ever lost your momentum mid-build hunting for the right wood sheet, this simple organizer idea may be for you!
I 3D printed a 6-slot letter holder — but you don’t need a 3D printer. A standard letter holder from Staples or any office supply store works perfectly!
The best part? Both sides are labeled differently — just rotate it to match your kit!
Side 1 — Smaller kits (2 wood sheets per slot):
A B | C D | E F | G H | IJK+ | Paper
Side 2 — Larger kits (3 wood sheets per slot):
Paper | abc | def | ghi | jkl | m+
A few other details that make it work:
Dividers are different heights — taller for the paper slot, shorter for wood sections.
Each colorful divider makes it easy to find your section at a glance.
Sits on my right side for quick, easy access during a build.
No more shuffling through a pile mid-build — just flip to the right side and grab what you need! ![]()
This has come up in the Robotime Community before, so I wanted to share my setup here too in case it helps someone!
(P.S. Sharp-eyed readers may have spotted my cat Licorice supervising the photoshoot in the background!
Have you found a clever way to organize your build supplies? Share your setup in the comments!
