Oxygen oasis help
hello there anyone started the oxygen oasis yet? I know I mentioned a previous topic before about it but this one is different. so the issues I have so far are the instructions in the Manuel. the steps aren’t very clear as to what you need to do. I know steps are in Chinese as well and just say the same thing in English I know because I google translate. however there’s one step in the manuel where you have to do the dome and to glue the dome windows together then add the rest on top. well I didn’t read the instructions carefully bc I started putting the window pieces in the slots and realized they were not staying in so I glued them in place not realizing that later on your supposed to take the dome part off in order for you to manipulate the big tree you make then tp put the green house frame over it and then put the dome back on. idk I see that it makes it easier but bc I made the booboo idk what to do. should I just try and manipulate the whole tree so it fits inside the dome or try to take the dome top off. I used super glue, I think maybe this is partly why I got mad there was no glue lol. feel free to let me know how to help if you can tell what I’m talking about or ask me questions if unsure take care and thank you
There are many who have done this one. I hope that somebody sees it and can offer some advice.
yeah Im sure lol. idk some may have started or completed long time ago get and forget how they did it lol and some may not be at the step I’m finished with lol. who knows but hopefully I’ll get some leads somewhere also I came across a tip if some one is having issues with doing the irisis for the front I ended up using my sister’s perfume bottle cap to stand them up and it worked perfectly
The only thing I have found to dissolve super glue is 100% acetone…and you literally have to pour it and quickly pry apart.
oh dam lol with my luck I might pour it all over the place lol and then maybe the whole thing might come apart. lol. I think I know what I might do and don’t want to do is cut the whole dome off with a knife just to place on top of the frame and re glue it lol. we will see when I get there lol. I think I’m half way there to make that big tree so I might hold off a little
I wish you the best of luck. This is why I rarely use super glue…but ALWAYS where wire is involved.
I have build this already and it was such a lovely kit. I would say don’t take it off because you already glue. You might damage it if you try to take it apart now. Use a tweezers to help you move the tree branches so it can fit in the dome.
I haven’t built this kit; I hope Robotime can help you.
I think using glue might make installation a bit tricky, since the tall pieces extend all the way up to the domed roof.
I haven’t built this kit but I know a lot of people in the community have. Best of luck to you! I sometimes use super glue in my builds and I always get frustrated when something gets glued in the wrong place.
Theres so many who have done this! Im sure they will help
Have you tried messaging Robotime?
Can you give advice about how to do the ivy? The instructions for the vines are very confusing since they rely on pictures and not necessarily words, lol. Are you supposed to keep 4 of the thicker green wire and not cut it at all? Thanks for any help!
I still keep the thick green wire ạ good length. I use the thin green wire for branches
Yeah all I did was make like 3 or 4 strands from the main stem and just wrapped those strands around the top of the pointy sticking from the top. Sorry I can’t get my words out today lol but yeah then after that I put the green leaves on kind of like a pumpkin vine almost I’ll send you a close up
