You are my welcome
Oh! I suppose the wood is too thin for you to screw the hinges on?
No matter Sue because this turned out absolutely gorgeous!
I really love how it opens up in multiple sections!
Suzanne_Jones, Molly’s Garden looks so lovely, and that front door hinge drama is such a classic last step surprise! You still brought it home beautifully, and I love that you kept going after the rubber band plan decided to stage a little rebellion. Also, the Starry Night Cathedral sounds like a gorgeous next adventure, what a satisfying pair of builds!
Thanks Serene. Much appreciates
It is really tiny Jill. But absolutely adorable.
Thanks @Zoe_Lau. I had actually put one part in the wrong place in the cathedral and had to pull it down to fix it.
Far too thin for screws unfortunately
Thankyou @Robotime. The glue gods had a great laugh at my expense.
Making the same flower shop atm. Had magic and bakery shops from the same set. The only way I found to make any door (wall) stay connected is by loosening that mechanic part on one of the sides. That way it needs no pressure to move (so the transparent sheet stays on spot with no issue).
Tho they never stay properly closed anyway LOL
Great job on those projects!
Thanks so much @Bebra.
You’re right that they won’t stay shut all the way. I’ve ordered the magic shop, and I have the Forest Wonderland to do next.
Good luck on them! The magic set is absolutely adorable :3
That kit is BEAUTIFUL!!! wow you should be proud of you, it turned out so good and well put together!
Awww. Thanks so much Miriam.
That’s good that you caught it. Can’t wait to see how the rest of it turns out.
@Suzanne_Jones you always’welcome ! ![]()
@Suzanne_Jones your welcome ! ![]()
You are most welcome! ![]()
This really looks so lovely! I actually like so small it is with all the details. Amazing job!
Thanks again for your comment Hailee.
Molly’s Garden turned out soooo lovely, even with the hinge battle along the way. It has so much charm, and the fact that it fits in the palm of your hand makes it even cuter. Also, pulling out the Starry Night Cathedral while the glue dried was such a good move ![]()
