👍 [Beginner Tips] Working with Fabric ✂
A lot of the older Rolife kits come with fabric that requires us to cut according to a pre-printed template. Depending on the quality of the fabric, this can be quite a pain as it’s hard to maintain a straight line while holding onto the paper, not to mention dealing with fraying edges. I also find that I often end up with a smaller piece than intended.:smiling_face_with_tear:
There’s already an excellent tip here Cutting Fabric with the Help of Glue, but sometimes I just don’t have the right glue. Or I simply prefer not to use any.
I decided to share this quick tip because it’s worked beautifully for me and it might help you too if Rolife ever brings back some of their older-style kits.
This was from my recent experience with fabric, and I was really happy with how clean the cuts turned out. :blush:
1. Any scissors will do but I find that a small sharp pair works best.
2. Use some tape to stick your template onto the fabric, making sure it goes slightly over the edges of your lines. If the fabric tends to fray, you can also tape the back for extra support and just keep it on when you’re done.
3. Cut as usual and you’re done! Here’s how mine turned out. You can easily peel off the tape afterward and it doesn’t leave any stains on the fabric. You can even reuse the tape if it’s still sticky.
4. This is the tape I highly recommend using. I’m not sure if other tapes would work as well and clean on fabric, so this one’s definitely my go-to.
I hope this is useful to some of you! :front_facing_baby_chick:
You have done so well with this. Thank you so sharing. Will definitely keep it in mind if I ever do any kit like that.
These are some great tips! :blush: It’s nice to see people sharing their build wisdom with the community! :heart:
What a fantastic tip! That tape does sound like magic :star_struck: thanks so much for sharing!!
Beautifully done! I love this idea
Thank you! I hope Rolife brings back some of these kits hint hint :laughing:
Hehe thank you only took a few curses and rage quitting to get here :laughing:
HahahHaha omg I never realised it’s called magic tape!
I hope it will entice you to work on some Rolife kits hehehe :laughing: :rofl:
@JDisaduck I’ve done a few…and I have Elsa’s Tailoring in my stash. This tip will certainly come in handy. Thanks again!
Thank you for sharing these valuable tips with us :smiling_face_with_three_hearts:
Thank for share tips. so useful
Thanks for sharing this tip :hugs: it could be very helpful if i going to make an other miniature kit
That’s such a clever idea! Thanks for sharing this tip!
You can clearly see this a better quality kit than what im working on. I made the cap as well. But mine was a beat where i had to wrap cloth over. I had that issue indeed that is was a little to small and some fraying happend indeed. I couldn’t make the bow in top as i already used all the string on a other part and fucked that part up so it will have to stay like this haha.
I hope you’ll try more miniature kits some day hehe :laughing:
The cap looked so much smaller than the one I made so I think you did an amazing job! Not sure if I’ll be able to make a bow that small to be honest. :rofl:
Haha i think it will take a while, because there a to much Rokr kits i want to make :wink:
There i a clear beat inside it where i had to glue the fabric around and then push it inside the bead and then turn it and glue it to the flat part. It goes on the coat rack in the end.
