Continuing the discussion from
[ROKR - Education] ROKR Dream Coffee Factory Step-by-Step Assembly Guide: Part 1:
Hi what is the brand of screwdriver you use please?
There is usually one or two in the kit that should work. Check all bags.
Unsure if I am answering question. If you actually want the brand, there is no name on mine.
I think you may be referring to a specific type used by @Martins_Assembly_H ? Is that correct?
I am so glad you are so knowledgable. I was a bit clueless!
Yes the one martin uses
I tagged him so hopefully he will answer. He is not on here often. If you belong the ROKR fans group, his name is Martin Staltmanis. It might be easier to reach him there. Make a post and tag him in it.
I generally just use the one that come with the kit and overtime i have collected so many of them.
The screwdriver was included in the accessory kit, and I didn’t need anything else.
Theres always screwdrivers included in these kits
Welcome to the community, Nicky!
Usually, if a kit needs a screwdriver, it comes with a small one.
@Nicky_Cartwright i use the one provided in the kit xxx
Thanks Nita for tagging me in, and yes I’m not here as often as I’d like just because I’m on so many platforms, it’s not easy to use them all ![]()
And it’s the Strebito screwdriver kit I’ve used for quite a while now: Amazon.co.uk but of course the kit does include screwdrivers if people aren’t up for investing in an electric one ![]()
You’re very welcome. @Martins_Assembly_H
