FAQ
AMC01 - Rolife- Classic Carousel
AMC01 FAQ
- Touching the switch the third time produces an effect inconsistent with the instruction.
The terminals are incorrectly inserted.
- What if there is no response when checking the electronic parts?
A1: It is not connected to the power supply. Use a 5V 500mA power supply with a Type-C cable for connection.
A2: The touch switch is not inserted.
- It cannot rotate after assembly.
Step 1: Check if two gears C7 are aligned.
Step 2: Check if the patterns on the F3 and the F5 are aligned with each other.
Step 3: Check if the gears are engaged. If not, Check if C4 is fully inserted.
Note: The inner gear is positioned slightly higher than the outer one.
- What should be done if jamming or uneven rotation occurs?
A1: Wax the gear.
A2: Apply grease to the base rail.
