Assembly Instruction
FAQ
ST001 - ROKR - Mechanical Orrery
Functional Problems
The connection of gears does not run smoothly:
①Check if they are adequately waxed.
②Check if the transparent shaft sleeves in step 1 are assembled correctly, and if the gear E25 runs smoothly.
③Check if the meshing of the handle and the gear E25 are engaged.
④Check if the Part i, Part I, Parts k, and Part j in step 16 are assembled correctly.
