I added sakuraglitter to the trees to add texture and feel of petals. I did not like the water by itself, so I wanted to add a bit of grass around the pond and blend the water of the square base with the mirror of the round base to blend the water into one. The white glue will dry clear and it should be a seamless addition.
I need to add a few more sakura petals on the side of the front tree and then I will be done. After a video that I will take and then ask AI to transition and create. This should be fun!
This is amazing!! Your twist on everything definitely brought it more to life! The grass is 10/10! Amazing job!!! And thanks for posting all the tips, its super helpful!
