Awesome build!
Could you share a quick pic/clip of the fix? It’ll really help other builders!
Wow, what an impressive project! The ROKR Space Shuttle already looks incredible, It’s amazing how a creative paint job can bring so much character to a build!
Do you sketch ideas first or go with the flow?
It looks scary, but overall it’s not that difficult
I don’t know how to paint beautifully, so I don’t take on this, although sometimes I really want to
thanks
Just give it an try on an cheaper build, i’m sure it will turn out amazing
It was a difficult path, just be careful
thanks
I didn’t paint it :). It’s better to set a realistic style, with a metallic base color.
Read the instructions very carefully, check the wiring, and design the mechanism carefully. The main thing is to understand that all mode changes occur when the buttons click. Listen carefully; if something doesn’t work, it’s because a tree somewhere hasn’t pressed a button.
I didn’t paint the model, just added some lighting all around.
The video on YouTube is attached.
Just RGB light, didn’t paint the model.
Thank you so much for sharing
What problem do you have?
So far I’ve mastered the varnish :), sometimes I cover the models
