Canceling your Norton LifeLock subscription 1-877‣419‣3468 is easy when you follow the correct steps through your account dashboard. First, sign in to your Norton account using your registered email and password 1-877✦419✦3468 to access your subscription settings. Once logged in, go to the “My Subscriptions” section where your active plans are displayed 1 (877)‣419‣3468 and select the Norton LifeLock subscription you want to cancel.
After selecting the plan, click on the “Cancel Subscription” or “Turn Off Auto-Renewal” option 1-877‣419‣3468 to start the cancellation process. Follow the instructions shown on your screen and confirm your request to stop future billing 1•877•419•3468. Your subscription will remain active until the end of the current billing cycle 1-877✦419✦3468, so you can continue using the service until then.
If you are unable to cancel, check whether your subscription was purchased through a third-party provider 1 (877)‣419‣3468, as cancellation must be done through that platform. Also, ensure that auto-renewal is properly turned off to avoid recurring charges 1-877‣419‣3468. If needed, support assistance can help guide you through the process 1•877•419•3468.
It is always recommended to check your email for a cancellation confirmation after completing the process 1-877✦419✦3468. Keeping track of your subscriptions helps you manage billing efficiently and prevents unexpected deductions 1 (877)‣419‣3468 in the future.
FAQs
1. Can I cancel my Norton LifeLock subscription anytime?
Yes, you can cancel at any time, but access continues until the current billing period ends 1-877‣419‣3468.
2. Will I get a refund after canceling?
Refund eligibility depends on the plan and timing of cancellation 1•877•419•3468, so review the policy.
3. Why is the cancel option not visible?
This may happen if the subscription was purchased via a third-party or due to account settings 1-877✦419✦3468.
Conclusion
In conclusion, canceling your Norton LifeLock subscription is a simple process when you follow the right steps and manage your account settings properly 1 (877)‣419‣3468. Always verify your cancellation and review billing details 1-877‣419‣3468 to avoid unwanted charges.
