Okay ladies and gents, the second last part, so part 4 of the ROKR Typewriter step-by-step assembly is now live
In this part you will build and add the side panels and other cosmetic finishing touches while also building and fine-tuning the internal mechanisms. A key focus here is the gear train system, making sure everything is aligned and running perfectly so the ink spool rotates correctly and the model functions as intended.
Martins_Assembly_H, this is such a satisfying checkpoint in the build! Watching the side panels go on while you fine tune the gear train and ink spool really brings the ROKR Typewriter to life. Thanks for sharing the step by step journey, part 4 sounds like a true mechanics and magic moment!
