I highly recommend this wax for getting to smaller knooks and cranny’s that the robotime provided wax can’t get to I specifically got this one on Amazon imported from America X
talcum powder also works great and isn’t greazy
Really? Talcum powder isn’t something I would assume worked thank you !
yep i applied it with a brush on the wooden cogs in build in the past and it worked fine
Thanks I’ll definitely try this!
Thank you for sharing. I haven’t seen that people. Will that get absorbed into the wood over time?
So far none of my builds have had a problem with it but if they do I will let you know X
I have often wondered if this wood wax would work well. I’ve been tempted to get it.
It works very well
Thank for sharing
Thanks for sharing ![]()
This looks interesting! Is it greasy?
Thanks
Thank you X
Yes X
Thanks for sharing tips.
I might try this when I start building my Rokr builds.
I totally agree with talcum powder.
Thank you for sharing some tips! There are some available wax from a bookstore here in Philippines that I do not remember the name.
Wow tags powder what a great idea… so easy to use as well.
Thank you
No problem X
