My daughter is building the above kit. It’s a pretty frustrating build because the decorative print is just paper glued on wood. When taking the pieces out, the paper rips and they don’t properly fit. Because the openings are too small. The paper becomes damaged when trying to fit parts. How do you all go about building a kit like this?
I’m sorry to hear about your experience. Maybe @Sasa can help you. She just completed hers
Thanks for tagging me! That kit is a total nightmare, haha—let’s see if I can help.
I’m sorry to say that I’ve had the same difficulties with that kit… there are a lot of errors; I complained about the exact same thing. My only advice is to remove the pieces slowly and sand everything down very well. I also found it helpful to use a small hammer—just be gentle, because if you hit too hard, you could break the pieces.
you can ask thé custom service @Robotime
I’m sorry to hear that. I hope everybody can help you
So sorry about your experience. I read about the same sentiments about this kit. You probably need a craft knife to cut the pieces from the board to prevent peeling.
Yes this is good advice. I have been working on a kit with some pieces where the wood flaked off removing from the board, and agree that using the knife helps.
I would think sanding the pieces first will help it to fit alot easier.
This is true and sanding them will also help in fitting the tabs
I do this when the tab doesn’t fit at all. This really helps a lot
I does this all the time. The best way to help it fit.
That sounds really frustrating, especially when the decorative paper is so easily damaged during assembly. It’s a shame when the pieces don’t fit properly straight out of the box. Hopefully the advice shared here helps, and you can still get a nice result without too much damage to the finish. Good luck with the build!
Thank you all for the very kind tips and advice. I really appreciate it a lot.
I am sad to hear she is not the only one with problems. I thought we might have gotten a bad kit from a bad batch, so we could talk to customer service but more people have that problem, it is what it is. Thank you for the tips. Really appreciate it.
Well, you could try sending them an email to see what they say.
Use a craft knife to cut the tabs holding the parts in the board which should stop the paper tearing when removing them. That should help with part of your daughters problem.
