Awesome! I just finished it and it works smoothly
. Any thoughts on what my next one should be?
I am SO happy for you. It is always SO important to pay strict attention to direction and placement of each part. I hope this helps you on your future models. SO many have struggled on this model and the problems are usually self-inflicted, sadly. I’m really happy for you because this a beautiful build. My top 3 are the DReam Gift Factory, Space shuttle and London Marble Run
I would recommend the dream factory.
Hello! We were unable to view the video you sent. However, we have determined that the issue is likely due to you conducting the test without installing the auxiliary part C14 , which has caused the landing gear to fail to stop properly.
Hello there,
The issue in the video is that the T2 switch is not pressed firmly enough, causing the entire operation to not end properly. As a result, the circuit board cannot receive the signal, and the light will not flash or turn on. The solutions are as follows:
Locate the spare H40 on the K board and replace it with the original H40.
Bend the copper sheet of the T2 switch to make it easier to press firmly.
