Any help would be appreciated, I truly don’t know what’s going on and I’m scared I ruined this after waiting weeks for it to arrive. Thank you!
I can’t upload the video i took, but this is the max the track will extend when I press the button. I made it to the step where you test everything and the arm opened perfectly but the track stopped here and went right back. I tried unplugging and replugging, turning it off and on, but nothing worked. I ended up pulling up a couple hours worth of work to see if I had messed up somewhere and to rebuild correctly but when I got back to this point where I could test again, the same thing happened.
Hello, please make sure to install C14 before testing this step.
The reason why the landing gear won’t stop is that C14 is not pressing down the T3 switch.
The directions say that you may need to insert part C13 for this test to work. I did not have to do so, but I hope this fixes your problem. You will have to remove it after testing. I can;t find my directions at the moment but I am pretty sure that is the part number. Just look at the troubleshooting page where you are doing that testing step.
Welcome to community @Microwave . I hope everybody can help you
Welcome to the community, @Microwave! I hope these instructions helped and you were able to fix it.
Welcome to the community @Microwave
did you solved the problem?
