Space shuttle LKA02
After assembling the base/launch platform I decided to test it again before continuing with the shuttle itself. After doing so the platform extended and slide out but i can not get it to go back up (Launch position).
Is there anything i can do to fix this ? Preferably without out disassembling to much.
Note: during the second test required in the manual everything did work as it should.
Greeting Niels
Welcome to community. I didn’t install this model, hopefully someone else can help you. Or you can contact @CustomerService
I hope someone can offer you some help. Im working on this one currently but I’m not that far into the build yet
Welcome to the community!
I haven’t built that kit; I hope Robotime helps you with your problem.
That’s a really clear description of what’s happening, Niels. You can check first the alignment, or band that was loosened orrr wax the sliding part. Not 100% sure since I have not done this one yet
Hello,
Could you please take a video showing the issue you are currently experiencing with the product and send it to our after‑sales email: service@rokronline.com?
We will review the video to determine the specific cause and find an accurate solution for you.
@ItIsKing26 hopefully @Robotime can help
You … :cherry_blossom: :blossom:
I am glad that everything ended up working out during the second test.
Hello and welcome @ItIsKing26
@Martins_Assembly_H has done a lot with this as well as customer service. So if still issues, may want to tag them and include video as that helps them tremendously.
Hope you’re able to get it sorted out! :crossed_fingers: Hopefully it’s just a small alignment issue or something simple. Wishing you luck with the fix — would love to see the shuttle once it’s complete!
Hey Niels,
About 90% of times this is caused due to the micro switch at the bottom of the shuttle supports not being depressed.
Look at that switch and see if it’s been installed correctly and also look if you installed a small wooden piece below it because that’s where that switch gets depressed against once the rails have pulled out.
Your rails probably look like they want to escape just now but they go back a little, and that’s good because the safety trigger is working as the motor is feeling that extra stress.
So what should happen is that the rails pull out just enough and the micro switch gets depressed and they stop.
The switch I’m talking is the first one you install in instructions, it’s the P12 switch.
And the wooden little piece I’m talking about is F10 found on page No. 6, but it might be on a different page for yourself as I’ve found out some have instructions on different pages for some reason.
Let me know how it goes.
Thank you for the mention Jeanne, I’ve responded and hopefully it’s a simple solution :crossed_fingers:
Always happy to share your info!
Welcome to the community & Happy to hear that they given solution
I’m glad they gave you a way to get it checked properly. I hope they can find the cause quickly and help you fix it without having to disassemble too much.
Welcome to the community! I hope you’re able to fix your problem. Robotime should be able to help.
Welcome to the community @ItIsKing26 and hopefully you get it solved.
My space shuttle started acting up during the first test when assembling the base (around step 4). It worked once and just at once it did not do what it was supposed to anymore. Luckily when I went back to it last Monday it just worked, and multiple times. So I hope the tip and info you got helped you getting it to work again. And I hope I will be spared of any further issues as I continue to build tonight :sweat_smile:
@ItIsKing26 welcome to the community! The Space Shuttle launch platform issue sounds frustrating, especially after the earlier test worked properly. Thanks for explaining the problem clearly, and we hope the builders here can help you avoid too much disassembly.
