I am on the second row of cannons (the gold and the black ones). Good news is the snapped right into their holder. Bad news is when I placed them into the slot on the ship, they were really loose. I have already glued a couple things down because they kept falling off (ropes, gate in front with little step ladders). I am thinking of gluing so I do not lose them. Would this be an issue @CustomerService? Also the bell - lantern thing up front. (arrow in picture) isnt secured down and wobbly. I tried to push down and it feels like it goes as far as it can, so is it just wobbly?
Thanks!!
Hmm looking at your photo I would imagine it’s fine to glue down the bell? I would be worried of losing it? ![]()
I also believe gluing it would be okay but I have not tried making this yet so let’s wait for someone to give us some info.
Hard to glue down as it doesnt sit on a surface. It kind of bobbles around.
I think you should wait for an answer from @CustomerService. I’m a little worried that gluing will affect the functionality of the guns.
I did glue down the upper cannons
those top ones did not move so I glued.
I glued the lower cannons too, and honestly I messed it up a bit because I didn’t glue them in the perfect position. Now sometimes it’s a bit harder for them to pop out when using the mechanism, but it works, sooo… ![]()
The upper cannons are no problem at all since they don’t move, and for all the parts that don’t move, I also used glue at different moments so everything stayed nicely in place.
I tested the mechanism that brings the cannons out and it worked well, waxed the heck out of everything. Once all was done, they were a little harder to move. They move but the switch is a bit stiffer. Not overly concerned because this will pretty much be a display
Yes, the same happens to me. But just like you, since it’s mainly for display, it doesn’t really bother me. And honestly, I have it displayed in my bedroom with a lot of pride!! hehe
This may be due to a cutting issue with some of the wood panels. You can use glue to secure them. If you don’t have suitable glue, we can mail you some alcohol-based adhesive.
I have glue so all good! Such a beautiful kit and it turned out awesome. Thank you!
I think you can glue anything that isn’t a moving part. It looks good so far @jeanneL ![]()
Thanks @liset! Yea some cannons do move and I just wasnt sure! All is well
