I like this Crank Classical Gramophone!
Can you put records on this one?
Yes! I have the same question. Is it functional?
@Wenbare yes, it has about 3-4 songs but you will be tired ![]()
@Jerry_Boswijk and @Wenbare is it functional, You can connect it to the power supply via USB, and then it spins automatically. You can also turn the handle yourself, but you’ll have to turn it quite a bit. The included record contains three songs. It also includes various RPMs, so I expect you can play other records on it as well. I haven’t tried it myself yet, though.
It’s so cool then! ![]()
Yesss, it looks so much cooler when painted!! ![]()
And making the build is a lot of fun ![]()
Wonderful ![]()
Thank you ![]()
