So…i started my second flower today which is the Red carnation flower..im having the same problems as @Jo1 but with the Red carnation, with wood slots not fitting or slotting in, pieces litterely shedding my skin just by trying to get them in..any tips on how to help? I dont have any wax and i just want a non broken flower at the end of it ![]()
@Alicesharpe omg hun it wasent easy i ended up using superglue that it held it together for me ! ![]()
Sandpaper in between tabs is helpful…a birthday candle will work for wax. There should be wax in your space shuttle.
Lol im just hoping I don’t snap anything
Oh does it? Ill use it for my flowers then ![]()
@Alicesharpe Alicesharpei tried everything even wax lol I went so carefull to …. After been given hints and tips xxxxx
I did snap a part but luckily it wasnt completely snapped ![]()
@Alicesharpe I had a few spares so check your board ok xxx
Ill make sure to check ![]()
Perhaps they should write to the people at Rolife and explain the problem.
@Alicesharpe ok
I hope you do x
Im not sure how to do that ![]()
On the Rolife website, at the top you have the support section.
Oh thank you! Ill check it out
Do you have a birthday candle or tea light? It will work and seriously make a difference.
Some have used Vaseline, I have read a few positive and negative responses with that
I dont use candles because of my fear of fire..but i do keep vaseline
You could buy wax. But I think glue would probably be more helpful.
She needs the wax to help get the petal even in to the slot. That was my understanding. Glue wont help much until inserted at least somewhat
We truly care about your experience
. You can submit your replacement request here
Part Replacement | Robotime
, or contact our after-sales team at
service@robotime.com
. We’ll make sure to assist you promptly and get the right parts to you.
You can try to sand the wood if it’s not fitting. That’s what I do
and don’t try to force connecting the woods so no piece would be broken.
