Question about gear in clock
A little unclear here. Instructions say to remove this piece?
but I am seeing it there in future pics?
It does not look like it breaks off? and it looks important.
What have you cuckoo builders done?
There was some parts in the middle prior, maybe that is what they meant?
I think it meant to remove the middle that had part F2 in it. I think I am ok!
I think you’re right. Luckily you found your answer :wink:
Oh gosh I can’t help you yet. I haven’t got that far. :grimacing:
well when you get there Dont take it out. It is not the grey gear, it is other pieces that are just placed in there due to space. I think it is F2 a smaller gear
Lucky I didnt break it off!! Going good and nearing the end!
You are very quick in building it.
I am just plugging away! Fortunate that I am retired and can spend a few hours up in craft room! Taking a break for news and dinner, then hopefully I may finish!
That’s nice. I work full time so my building times are limited.
Simply remove this part.
Thanks! I ended up figuring out. and removed correct part.
Oh my, it’s always scary to break the pieces aahhh :see_no_evil_monkey: I’m glad everything goes well
It was tricky. There was actually a middle section that contained additional parts and that is what was to be removed, not the grey gear.
I see :face_with_spiral_eyes: thanks to share this here~ like that, if we build this too, we will know :see_no_evil_monkey:
If you look at the backside and it’s not cut apart, it doesn’t come out.
