Congrats on your prize. This is a wonderful kit. Enjoy building.
Thank you
You’re welcome
Congratulations!
Thank you.
I see but the box looks like an old kit for me. Have fun building that and congrats btw. ![]()
Thank you so much
You’re welcome. ![]()
So happy for you. Enjoy it whenever you get the time, the spinning wheel always makes it fun!
Congrats! Looking forward to see your final build ![]()
Thank you. I will try
Thank you.
That one is my favorite model so far that I done!
If, when you first play a disc after assembly, it play backward, don’t panic (unlike me XD) and look for the switch on the circuit board that reverse playing direction. (mine arrived with the switch set on “backward”, and I didn’t know the switch was there so I panicked at first thinking i assembled it wrong XD)
Thank you for your guidance. I will take note of that.
Congratulations! This is gorgeous. So happy that you got something you’ve wanted for so long.
Thank you,
It is not. It is not new…but it is still always available. Here is mine. ROKR Gramaphone final pics
I see. It’s maybe an old kit since I’m not familiar with the box. I will check your post about this kit too. Thank you for sharing it. ![]()
The square base is around 18cm, the disc support is slightly wider than the base, it’s about 20cm total
But the sound horn “exceeds” from the base quite a bit, one way or the other, so if you orient it straight aligned with the base, you can hit 40 cm total “width” but it’s not actually 40 cm all the way top to bottom
