LQA01 Rotating -barrel machine gun
I am having trouble with center 2 gears that connect. Piece is not fitting and unsure if the cut is slightly off or what. Photos do not show how it should fit, only where it goes. Please help. The blue outlines piece does not fit through the bottom grey circular piece
Welcome to community. I haven’t installed this product, so I can’t give any feedback. You can ask @CustomerService for help
It appears to me that certain areas need to be in an exact position.Make sure that those are aligned correctly according to the picture. I would try sanding the inner ring of the piece that you are trying to go into..and doing the same with the piece that you are trying to insert.
Hello! Please provide us with the actual item images so that we can identify the problem.
There are little slots on the side as in the ring it goes in to. These need to be alligned and then there will probably be a part that locks them.
Uploading: image.png…
After installing H6, you can then inst all this component.
