My main switch appears to be positioned wrong and won’t engage the switch when flipped. Is there an easy way to adjust the part (part C5 page 13) without reversing my build completely? I’m about to wedge something in there so it’s always engaged. I got to the 2nd power test and everything else works perfectly
Update: I ended up deciding to reverse about 5 pages of build. It took a lot less time that I thought it would and everything went smoothly. Back on track now! Thanks everyone
Oh no…I am not currently home to view my instructions…BUT, I don’t think this can be easily corrected. If it works in the opposite way ( Off means and On and On means on…then that is up to you.) Sorry I couldn’t be off more help. Maybe if you send a pic of that part being installed in the instructions, it might help me to figure something out. I don’t think I would be wedging anything in there as a “correction”. This thing goes thru a series of steps and I don’t think that is a good idea…but @Robotime may have a solution that I am unaware of.
I dont see what wrong. But the best way is always to go back and correct it. Like the others say wedding something in between is taking a risk of braking everything. Do you have a clue what you did wrong. I don’t have the book anymore so the part number says nothing to me
Welcome @Carlos_R Glad you were able to make it. I once had to take half a structure apart because I’d done something wrong. Luckily, it didn’t take you too long! Good luck with the rest of this build!
