Little bird not coming out all the way
Continuing the discussion from A Little Tick-Tock Magic! :heart:: I’m almost done with my cuckoo clock but got stuck with the bird not coming all the way out and sometimes don’t go back in or get stuck.
Any advice please?
Need a Hand?
@Yolande_Weiner I did not build this one , can’t help you with that sorry. @MamaNheza just finished this kit, maybe u can connect with her
Hoped u can resolve it soon. :folded_hands:t2:
I had to check the lower wires that push the bird out and pull it back in. I think they may be connected to the shutters if I am correct? I hope that you can find the problem.
Welcome to community. Please check the power supply and the bird-pushing mechanism.
Hello,
We have reviewed the video and it appears that the issue with the bird not coming out fully or getting stuck may be related to the motor (P25) or the circuit board (P24), as we noticed that the motor is unable to reverse direction.
We would kindly suggest that you visit our replacement parts system to request replacements for both parts:
Once you submit your request, we will process it as soon as possible.
Welcome to the community! :slight_smile:
Hope you can have this issue resolved soon.
You could ask @CustomerService
Welcome to the community! Maybe Robotime can help you? I hope you’re able to solve this problem soon!
Welcome to the community, Yolande! I see that Robotime has already replied to you.
I have not worked with this one yet. I hope @CustomerService can help you
That’s great that Robo has suggested replacing the parts for you. I hope it will fixed for you as soon as the parts arrive.
Welcome to the community @Yolande_Weiner
Hope your issue gets resolved
@MamaNheza recently build this kit. Maybe she can help you or @CustomerService :blush: welcome to the community. :pink_heart:
@Yolande_Weiner welcome to the community i hope you have now fixed the problem wishing you all the best of luck
j’espère que tu as trouvé une solution
Welcome to the community, Yolande! :smiling_face_with_three_hearts: I hope you get it sorted soon. It may be worth checking that the bird mechanism is moving freely and that nothing is rubbing or catching along its path. You could also gently move the mechanism back and forth manually a few times to help loosen it up. Also, is this part here already pressed down? I noticed the bird seems to stop there and then moves again. Maybe that’s where it’s getting caught? Hopefully a little adjustment gets your cuckoo popping out properly!
Thanks everyone for your responses and welcome :hugs:. I’ll check out the replacements and hopefully will be cuckooing soon!
