I’ve built this same model before and it worked This tie though it’s not allowing me to turn the load wheel back to load additional bands. I am positive that I built the part right as the other barrels work fine. is there an ad
I still don’t understand your problem.
Sorry - it didn’t post correctly. I’ll try again. I’ve built this same model before and it worked perfectly. This time it’s not allowing me to turn the load wheel back to load additional bands. I am positive that I built the part right as the other barrels work fine. Is there an adjustment that can be made after everything is built?
Hi sorry I’ve not built this before but I’ll tag @CustomerService so they can give you a hand. ![]()
Sorry i didn’t make this build so i can’t help you, hopefully the customerservice can help. Maybe you can make some pictures of the problem, it will help to solve the problem
Can you see what’s blocking it? I’m afraid only thing to do is take it apart and sand and wax everything.
Hoping @CustomerService will be able to help you with this.
Did the jamming issue occur before installing the six-barrel assembly, or after it was installed?
