Ok, where is the info on how to upload a pic to my post? I see how to upload a video but don’t know where the pic info is. Thx.
This link is from an earlier post of mine which tells just how to do this.
how to upload a pic
Depending on your device being used, you may need to click somewhere outside your text box, then select the icon and will see choices. I use an ipad and it can be finickywith the website
Thank you both. Clear as mud before your response. A mouse-over the icons at top doesn’t open an explanation but now I know.
Wonderful! Please let us know if you need help with anything else! We try to help as much as we can and if we can’t, tagging Robotime or Customerservice (with that @ sign) they usually can!
@Jill_Francisco well i learned something new about this post also, didn’t know you could it that way
I hope the others were helpful enough for you!
Another thing I would mention is that you wanna add a photo before any text, if you want that photo to be seen as a head picture before opening your topic. Not sure if I’m being clear enough ![]()
Again, thank you all for being so helpful. While I am at it, a question about changing my email address. When I signed up, I had to use my gmail address. I never use it and don’t particularly like Google. I went to my account preferences and it does say i can change my email address so i tried. Even though they said a confirming email would be sent it apparently goes to my gmail address. I suppose i will have to figure out how to get into my gmail account unless there is another way to change.
It could be that @Robotime has to help you with this. They have some controls in place to protect integrity of this due to point awards and things.
I tagged them on this so that they might help you as needed.
Thanks for the shout out the big guys.
About video if you have long video, you must upload youtube and share link
If you are using a laptop, you can simply paste it or use the arrow that point upward that says upload.
Hello there.
I think the question has been answered. I would also like to add that if you’re going to make a post, you should select correct tags and clear the text in the description before typing your own post.
Just a tip if you haven’t noticed this yet…when you choose multiple pictures to upload at once, they load in reverse order. That’s annoying if you wanted a certain one to be listed in your post first, so I have learned to upload the important pictures individually first and then any others can be uploaded at the same time. I hope I explained that ok. ![]()
I don’t recall that that has ever happened with me. Maybe it depends on the device you are using? @Tkaplan I don’t usually upload too many at once though, cuz it takes forever…from my phone. On laptop, I do two at a time.
