Henrys Chocolate Lights
My Henrys chocolate shop light recently started getting darker as if its not as bright as it was when i made it has anyone else had these troubles? I do use battery convertors
What does the battery convertors difference with an ordinary battery?
You plug in a battery convertor to convert it to electricity X
Cần you show is a close up of it?
The Light box, the light bulb or the battery convertor?
I’ve not had that issue but then I don’t turn my lights on all the time.
I keep mine on between 4:00 and 9:50 It shouldnt break that easily right?
You should check the light bulb, the battery, and the wiring connections.
Okay i will X
Hm maybe try to change it into batteries first if there’s a difference between them. Maybe it’s not getting the right electricity.
I will X
Does the issue still persist after switching to battery power?
Ill be testing it soon ill let you know X
Ive switched to batteries and the lights flickering i think i might use Led lights X
The battery converter please @Lacey if you have any questions don’t mind.
Looks like you’re getting help…I hope you get it figured out.
I did thank u X
Hello, we can confirm that the LED bead has suffered from desoldering. We are willing to provide you with replacement parts free of charge.
I managed to use led lights thank you x
