Assembling the space shuttle LKA02. The arm retracts and the cradle moves out and back in. Has a little wobble once it’s fully retracted but the arm will not return across the front. Any help please? Won’t let me upload the video keep saying an error.
Have you tried inserting part C14 before the test? I didn’t have to but man people needed to. I think that is the part number. I am not currently at home to view my instructions. It tells you the part number on that testing page.
Yes, I did, definitely an issue with that Rocker switch not being touched. If I press it with a tool it works. Just can’t see what is meant to be pressing it because it’s that part doesn’t extend far enough.
I am not currently at home to view my instructions but maybe if you send a picture of what switch you’re talking about, I might be able to help you
Welcome you. I hope everybocy can help you
Welcome to the community, @Magners.
I haven’t built this kit myself, so I’m not sure how to help, but I hope Nita’s advice works for you. If not, @CustomerService should definitely be able to help you sort it out ![]()
Nothing is touching this switch on the return. If I press it, the carriage stops retracting and the arms all return. I’m guessing something should be touching this when it returns?
If you want to upload the video. Upload it on your own youtube account and paste the link here. Then it will work and we can see if we can help you.
I’m sorry I can’t be of help. Without my instruction booklet, it would be hard to back track and see what could be wrong.
Hello, C14 must be installed to press the T3 switch and trigger subsequent operation.
It is installed??
