Help! - Starry Camellia Lamp
you can take out the flower to test, the string at the top should up & down when you switch on… if work then the flower need to loss a bit for the screw… do you understand what I trying to tell you…? :rofl:
Yikes, I’m sorry that this is happening to you. I have this in my stash as a gift from Robotime when I bought the coffee factory. I’m gonna follow your post for any response from Robotime
Wow never seen this model before.
@Kit_Mun I think I know what you’re saying. I will have to try it.. thank you
Your suggestions haven’t worked. I’m so sad…these kits weren’t cheap and I’ve never had a build not work. I’m still waiting to hear from @CustomerService for help.
I do appreciate your help and ideas to fix it.
Do you mean that the metal which cover with the green layer wasn’t up & down when it switch on…? :thinking: Yesterday I was reached home quite late so I don’t time to carry out mine… :zany_face:
Currently I’m on working… will try to figure out and show you after I reached home if your problem still not solved… :heart: I understand your feeling and don’t be upset…should be have the way out :heart:
@Kit_Mun thank you so much!
@Tkaplan I have upload the video in my IG
https://www.instagram.com/kitmun_corner?igsh=bXIxOXlrYzZhMGk2&utm_source=qr
Because the video quite long and my slow motion :rofl: hope it can help you​:wink: if still not working we find out together​:heart_exclamation:
@Kit_Mun thank you so very much! I will watch your video tomorrow and see if I can get the flower to work. I’ll let you know what happens!
Hello, could you please send us several videos showing the fault condition so that we can determine the cause of the problem?
@CustomerService yes, I will try to do that.
What a bummer that it’s not working! Has the customer service found a solution yet? I can’t help you, unfortunately, because I haven’t made this kit yet.
@Liset customer service has reached out but I haven’t been home to work with them on it.
