HELP - Cuckoo Clock assembly
Hii!! I really would love some help with the Cuckoo clock assembling. I did the first part of the building and I was testing to see if the bird would work. It chimes but it won’t move forward through the window. I checked and I feel like I did everything correct but it still not working. I believe this mechanism is the part where it goes wrong but I followed the steps for that part so not sure what I am missing.
Welcome to community
Look at the magnet part. It seems like that part helps the bird move.
Hello, @Bodhi, welcome to the community!
Could you show a photo of how you’re fitting the piece into place? In my case, at first it didn’t work well because everything wasn’t fully fitted in correctly yet. Maybe with a photo I can help you a bit more. I’ll show you how mine looks:
Yes what @Wenbare says. That piece has to be securely placed. I remember finding a small magnet while cleaning up kits, but I never did find where it should hace gone! So @ThaoNguyen please take a pic and let us know where the mystery magnet goes. Mine does work without but you never know!
First, check the alignment of these white gears. This will help the bird perch slide out smoothly.
And this is the magnet I was talking about. When attached, it’s the green part as shown in the instructions.
Welcome to the community @Bodhi :hugs: Did the tips help? Otherwise, you can always ask @CustomerService for advice.
I stuffed up with this part too. So when I figured it out, I have to push the brown part down. You will see the spring will push it back up. That’s when it’s correct.
Hello there,
We’re sorry for the trouble with your product. Could you please send us a short video showing the issue? Our team will check it and, if needed, send you free replacement parts.
If it’s an assembly problem, we’ll guide you through the steps.
Thank you for your patience and understanding.
@Bodhi Welkom bij Robotime community!
I’ve forwarded your problem to our customer service team :wink:
Feel free to share anything & have fun here!
Hi everyone.
I’m having the exact same problem. Any news on how to fix it?
