Cuckoo sopped working with clock
Changed the batteries and now the cuckoo only works intermittently with override switch. Mostly the lights just flash when override switch is pressed.
Hi :yellow_heart:Unfortunately, we’re unable to view the video on our end. Could you please try uploading it again? We’ll do our best to help​:blush:
If you are unable to send the video normally, you may send it to our email address: service@robotime.com
Welcome to community. Sorry video not play
Oh no! :pensive_face: If the batteries are new, it might be a connection issue since the lights are still responding. Hope you’re able to get it working properly again soon! :crossed_fingers::mantelpiece_clock:
@Tom_McCombe welcome to the community i hope you sort the issue …
Welcome to the community!
I see RoboTime has already helped you, I’m glad.
Hello and welcome @Tom_McCombe
These are some of the things to do from past experiences.
  1. If using USB, remove batteries. Do not keep batteries in there!
  2. Be sure USB charge is correct amp size.
  3. Check that cuckoo is not stuck. There is a spring inside the cuckoo part and if it is not set snuggly, can cause issues. Also the tiny bars by cuckoo door can cause issue.
    Be sure to make video and send to CS. They are wonderful to help
Welcome to the community! Sorry you’re having problems with your build. Hope you can fix it soon!
Do you still have the instruct. From the begin? It says something like place hands at 12H. Then turn wheel until…. It worked for me…. Kind of reset :slightly_smiling_face: and also mind the flashing light..( 2 different kind) with/ without koekoek
@Tom_McCombe welcome to the community! Cuckoo Clock behavior after changing batteries can be frustrating, especially when the lights flash and the override works only sometimes. Thanks for describing it clearly so others can help troubleshoot.
@Caroline_Vandamme welcome to the community! Thank you for sharing what worked for your cuckoo clock reset. Practical notes like the hand position and flashing light details can really help another builder who is stuck.
