Cuckoo clock not working at all
Started working on my Christmas present today, unfortunately none of the functional tests are working.
  1. Hourly time test doesn’t work, I can hear the click but no cuckoo.
  2. Test function neither switch does anything: no lights, no cuckoo.
  3. Type C adapter test does nothing either
Can someone please help.
Hellooo welcome to the community. :blush: I’m sorry I can’t help you but you can ask @CustomerService maybe they can help you.
did you check if all the connectors are fully pressed into place?
Yes, I’ve even had my multimeter out checking voltages.
then it might be a problem with the circuit board and you can request a new one on the site.
Hello! If you remove the battery and test using only USB power, is the result the same?
Welcome to community. I think there’s a problem with the main circuit. Please double-check by using the correct Type-C power supply. If it doesn’t work, contact @CustomerService
Welcome to the community, @Robert_Park! I hope you were able to fix it with the suggestions everyone has already shared :slightly_smiling_face:
Tested with both battery and USB adapter
Many thanks for the replies.
Just to let everyone know by way of an introduction, I’ve been building models for over 50 years, I’ve built many ROKR models and before I retired I was an aircraft electronic engineer (avionics) for almost 40 years in the RAF.
I was hoping I could do that but don’t have a clue where to request the board
You can request for replacement part through this links.
Good luck @Robert_Park
Many thanks, I’ve just sent the form off, hopefully I’ll hear from them soon.
They are usually very good and the service are very quick.
CS have done their job, they’re sending out all the electronic parts just in case it’s not the circuit board. I have a feeling it may be the battery box as I was getting some odd voltage readings.
We can provide you with a fully tested set of electronic components.
Thank you, I think I have a set of parts being sent out
